TwinTurbo.NET: Nissan 300ZX forum - Re: 2nd Gear Grind Theory
Subject Re: 2nd Gear Grind Theory
Posted by 300ZMang on July 18, 2012 at 12:51 PM
  This message has been viewed 311 times.
In Reply To 2nd Gear Grind Theory posted by daygobaker on July 18, 2012 at 11:14 AM
Message On these cars, most of the time it actually is the synchro grinding.
If you try changing your tranny fluid (to Redline, Amsoil, Royal Purple, etc.) you might get rid of the grind.
Also, these cars don't go into 1st gear too easily when in motion (it's a safely mechanism). However, if you're rolling, and can't get into 1st, try revving your engine while you're trying to shift into 1st and clutch is to the floor. This usually helps ease it into gear.
